Pascal Parvex
You know, it would be neat to have a CineAlta at home, but apart from the fact that I could barely lift that thing, how am I supposed to process the footage? I mean, I have a 3.06 GHz 533 FSB CPU with Hyperhtreading, one Gigabyte of 266 MHz RAM, FireWire and a 7200 RPM hardisk, and even with this, SD DV is clumsy enough to handle. I once exported about 2 minutes of DV in 1920x1080 24 frames progressive with Blade 2. The File is about eleven Gigabytes huge. When I play it with Quicktime, it goes like this: I loads five seconds, then the video will play slowly for two seconds, the it loads another five seconds with freezed video to play then another two seconds and so on.
So, how will this work for the new Panasonic? Do I have to buy a Quad-CPU-System with four HT-P4s and High-Speed Harddisks with loads of RAM?
By the way, right now I'm exporting thirty seconds of DVX-DV to Film 2K, the highest possible thing in Blade 2. I wonder, how this will play.
And...if I should buy the HDX anyway, I will wait for the bugfixed HDX100_A_.
