magoo
I have DVX100E.
a. I can shoot in letterbox but it not only cuts some top and bottom off , it also stretches it horozontally. This is my non-technical explaination anyway. So it is probably doing what it should.
b. I may be getting vid from a HD Sony that can do 16:9.
c. I also may be getting vid from a little Canon 840i that can do widescreen - which seems to mix nicely with the HD 16:9
What format size do you suggest I shoot to enable use of all 3 in the final edit.
To me it seems that the 4:3 can fade in and out of 16:9 sort of OK from a viewer perspective - as long as there is not too much back and forth. BUT I am having difficulty seeing how I can use DVX letterbox effectively if I will be getting true 16:9 or widescreen to mix it with since the letterbox seems very stretched when watching on TV in 16:9 mode (which is fine for the HD 16:9 and widescreen footage).
Again - the question is - what is the best way to combine these formats into a finished product? Should I just use 4:3 for everything in the first place? I have not visually successfully put the 16:9 footage alongside the letterbox so are there some suggestions on how to do this better?
I hope this makes sense.
