How can I get higher rez grabs??
Existentialist
I don't know what I'm doing wrong.
Check out my grabs here:
http://www.dvxuser.com/V6/showthread.php?t=136591
I'm shooting with a DVX100A, 24p, squeeze mode. Then I capture w/ FCP, here are the specs:
"24 frames per second
H.264 at best quality
24 bits per pixel
720 by 480 (anamorphic 16:9)
WARNING: Audio device is missing
Input: first 2 channels
Format: 48000 KHz 16 bit 2 channel
speaker: off
volume: 100, Gain: 0
Any ideas/suggestions?
Couple of problems, first, since you are anamorphic 16x9, you need to unstretch them to make them look right. Second, your focus is off which makes them appear less res.
