Hot swappable batteries?
Does anyone know of any product that will allow you to hot-swap batteries with the HVX?
Such a unit would have two battery packs-- when one is about to run out of juice, it would switch to the second battery. You could then remove and replace the dead batery with a new one, and the process would continue. That way you could shoot forever on battery power without having to hook the camera itself to AC (which I don't even think you can do without shutting off the camera...so you have to stop shooting eventually, if using batteries).
Am I dreaming, or could (does) such a product exist?
You could use a Power adapter from a V-lock battery system. Then you could use stackable IDX Endura batteries and just change the one on the back - the closer one would cover over the change.
- Mikko
