Is it possible for audio to be hot/distorted, but software shows levels to be only barely in the yellow here or there. There are no red peaks. We recorded some stuff and the levels in the camera showed the audio was around -12dB, but it appears to have been recorded lower and then some parts (the pops) are hot/distorted for a millisecond here or there, but the levels don't show red.
This is the first time this has happened to me. Any thoughts? Thank you.
Sounds to me very much like the the higher gain settings of the preamp are overdriving the camera inputs, as others have suggested. The MM-1 is designed to drive a +4dBu input and has enough gain when cranked up to take a very low level dynamic mic's signal and boost it that far. The camera specs indicate the camera's line level sensitivity is 0dBu while the MM-1 has enough gain the easily exceed that with higher output mics. It's very unlikely the mic is overdriving the preamp. Instead, as has been mentioned before, one can clip right at the camera's inputs and distort the signal BEFORE the recording level control can tame it. Try this setup procedure ... connect mic to preamp to camera. Camera input to line level of course, preamp gain full down, preset and lock down camera recording gain to 2/3 scale. Gradually increase the preamp gain while speaking into the mic simulating a normal recording environment, increasing preamp gain until the camera meters refelct a normal recording level for speech, -12 dBFS or so. The preamp gain setting so determined becomes the standard setting for that mic, do not try to use the preamp gain to ride levels during recording. Instead, treat it as a coarse level control with fine tuning during the scene done with the recording levels on the camera. A more typical application for the MM-1 is as a headphone amp for the boom operator and a line-driver between the boom operator and a mixer where the mixer is riding gain - the MM-1 is set to a standard level for the mic in use and left there.Thanks guys. I actually did some more tests and it's definitely overloading the preamp. I used AC power with my preamp and tested two different Sennheiser shotgun microphones (MKH416 and MKE600) on two different cameras and even into a zoom recorder.
I can use 18, 28 and 36 (dB) on the preamp, but anything above starts distorting. I did a test at 66dB and you couldn't even understand what I was saying in the recording...but the levels bounced at -12dB.
So it's either a bad preamp or it's supposed to be like this. Anything below 36dB works perfectly.
Depends ... the optimal setting for the intimate conversation between two lovers will be quite different from recording flight operations on a carrier deck. You want to send the camera a signal that will have the meters at a proper level when the input gain is between a half and two-thirds the way up.What would be a safe amount of preamp gain applied to a microphone like the Sennheiser MKE600?
http://www.bhphotovideo.com/c/product/878340-REG/Sennheiser_MKE_600_Shotgun.html
Glancing at the online manual for the H1 it appears the input gain setting shows on the display as a number between 0-100. Set it to 60. Adjust the preamp gain to give you a level on the meters of about -12dBFS with normal speech. The maximum input level for the recorder is 0dBm - if you set the preamp too high it's likely to exceed that and distort before the recorder's gain controls can have any effect.I don't have test tone and my setup is very basic. I'm going from the MM-1 preamp into a zoom h1 recorder. It's set to line. On the preamp, I have the choices of 18, 28 or 36 (any higher setting causes overload as others have mentioned). I have been keeping it at 18 or 28 to be safe and input levels in the zoom recorder are around 40-50 on a scale of 0-100.
The recordings sound great...but I was just wondering for my own knowledge.
Your problem is not the MM-1 itself, your mic is not overloading it. The problem originates at the input to the camera or recorder. There's a preamp there as well and the recording gain control comes after the input circuits. If you feed the recorder too hot a signal, the input preamp can overload before the gain control has any effect. Just keep the MM-1 at an appropriate gain setting and you'll be fine.I'm going to test one of the juicedLink or Beachtek preamps and see what the difference is compared to the MM-1.
