Horrible artifacts/glitches in shots!
davidnssbm
I think I'm going to cry. Is my camera busted?
I've been adding saturation to my shots in post to make them more colorful, and in doing so I've noticed horrible horizontal glitches through out the shots. These happen every few frames. When the video plays you can't see them as bad as they look in the still shots, but there's definitely noticable artifacts.
Does this have something to do with my camera? Why is this happening?
When I add the de-interlace flicker it removes them, but I shouldn't have to do this! Is my P2 card busted? Is it because I pointed the camera up towards the sun for a few lead ins from a lens flare shot to a building?
Any help would be greatly appreciated.
I didn't notice them until my NLE weeks later, so I don't have them on my P2 card right now to check, but I just noticed something: if I edit on my powerbook G4, I Don't see this artifacts. It's only on my G5 w/ display that I see them.
Furthermore, these were shot 108024, and recently I've been shooting 720p for another project theres been no problems at all.
If you don't see the issues on your G4, then you know the footage is good. If you don't see it on playback from the cards, then the footage is good.
Looks like improper interpolation/interpretation of the frame rate -- perhaps pulldown removal was off?
if memory serves me right, it was turned off, because that was the solution for importing clips that had the RED ! next to them
Well, I meant "off" as in it was off-cadence, not turned off. :) What are you viewing these clips in on your different machines?
Are you viewing .mov files you created by logging/transferring files on just one machine, or did you log/transfer on both?
im viewing the log/transfer .movs on ONE external harddrive that I plug into both systems depending on what location I edit at, so it's the same source for the .mov, but different computers.
another very good example of why you should move your P2footage to a drive BEFORE doing the log and transfer in FCP. that way you would technically still have your native P2 state.
no because im opening the same project file on each computer.
Wgzn, do you mean I should use P2CMS -FIRST- so i have the contents folder and THEN import those folders to the log and transfer to get the .mov?
It is for sure interlaced. I've ran into this before. While importing the raw p2 files into FCP you have to remove the pulldown or you will have interlaced frames.
When I've fixed this before I just re-imported the files into FCP using the pulldown removal and made sure I edited on a timeline with a frame rate of 23.98. To do this you need access to the original p2 files.
Applying a de-interlace filter will only blend the two interlaced frames together making that ghosting effect you'll see in your screen grabs.
