How do I take out the Horizontal lines. Everytime i deinterlace i can still see the horizontal lines. I use Adobe Premiere 2.0 What do i need to do?
this question has probably been asked many times?
Please help me with some advise?
You shouldn't see any horizontal (interlace) lines in 24p footage... if you are using the right timeline. You are probably using one of the standard timelines (e.g. NTSC DV Widescreen 48kHz, etc.). You need to use one of the Panasonic preset timelines, and the interlacing will be removed automatically.
Never use the Deinterlacing feature on progressive footage, you'll wreck your resolution.
If you are watching progressive footage with horizontal movement, on a (traditional) interlacing tv, you will still see the "mouse teeth" interlacing jaggy edges, only they will be between every other field, instead of every field .
A progressive scan tv is the expensive answer !
Blast !
