The reason for asking this is that the Varicam 35 has been out for a while. If there was a sensor issue someone should've noticed it by now. The Varicam LT uses a different codec (AFAIK, correct me if I'm wrong please) so therefore I'm thinking that perhaps the codec, or the reading of the codec by the software, is creating this issue.
New cameras arrive with new problems. The Varicam35 could never have had this (I don't know), but it doesn't mean the hardware in this one isn't causing it.
I hope it's software and easily fixed with firmware.
I was up all night yesterday and waisted time doing stupid mistakes installing the P2 software, and also trying to figure out how to best mount the camera on my shoulder since it's quite bigger than my FS700.![]()
I can try to check it this evening. What sort of settings do you use when you see it the most, and in what sort of light?
Ok, I'll give it a try!
Thanks!
Alex, here's a file that you can download. I shot it in 4K and scaled it down to 2K in post. The first part is shot at ISO5000, the second at ISO800. I've increased the contrast a lot in Resolve and also applied a pretty aggressive S-curve also. I don't know if the "motive" is ideal but I tried to change the aperture, so the picture is both over and under exposed. I'll try to get the camera out some day soon and shoot real life scenarios to se if something appears then.
https://www.dropbox.com/s/4lexyqx73r5lwkh/Varicam LT test.mov?dl=0
I tried to see the line but I guess I'm not sure what to do in post to make it visible, but I noticed something that looks like a "dead" pixel.
Edit: Okey, that was hard to see. Let's try it this way instead:
https://www.dropbox.com/s/wzsj51r32qc8uch/pixel.tif?dl=0
I tried to see the line but I guess I'm not sure what to do in post to make it visible, but I noticed something that looks like a "dead" pixel.View attachment 116743
Well, no sadly. I notice it in some older 2k shots now and I blackshaded many times since then.Just like Run&Gun said, a black balance will probably get rid of that pixel.
