Horita SCRIPT KIT Portable Wireless Field Logging System
Script Kit PA Logging Clipboard w/ Software
The Script Kit combines the Horita PTR portable LCD time code reader and a WTS100M wireless time code system into a powerful, easy to use field logging system. The units are enclosed in a sturdy anodized aluminum case mounted on a clipboard that holds pre- printed Script Kit Log sheets plus your script and other documents inside. The windows- based PTR-LOG program is included to quickly download into your PC the time codes captured by the Script Kit.
Includes Horita PTR, Wireless Mic system, aluminum case, clipboard, pre-printed Script Kit Log sheets, software for downloading PTR files, and RS232 cable.
The Horita PTR stores up to 50 numbered time code values that can later be recalled for display or downloaded to a PC.
Important Info
The TC reader installed in the Script Kit is the PTR Portable Time Code Reader. It'll read 23.98/24, 25, and 29.97/30 fps time code. The bundled PTR software will allow you to save captured time codes and optionally, associated comments, in a CMX340 format.
The Script Kit is a complete system including an RF transmitter and receiver. Additional receivers are available. The transmitter and receiver are OEM'd from a low power wireless mic system. The range of the units is spec'd at 100 meters line of sight. The degree to which the range is affected by obstacles such as buildings or walls really depends on the composition of the obstacle. An hollow interior wall will impede the signal much less than say a stucco wall full of chicken wire. RF/ EMI interference may also affect the range. The system operates in the 169- 171 MHz range and may be affected by other wireless equipment operating near this band or other harmonic frequency.
