Yeah Panasonic really blew this 'naming' in a big way. All they had to do is name the file 1,2,3 or using the actual date.time.xxx (whatever they wanted after that letter or numbers) PP and Windows can't figure it out. Unfortunately PP does not allow to sort by time.(that I am aware of in PP 1.5) I have to pluck one file at a time or a few at a time but not all. (FYI: I do have CS5, but in PP1.5 I can just drop into the time line, set chapters every 10 minutes and say make DVD and done... no need to do the Encore thing)That's how the AVCHD files work, but not how the DV files work.
In DV mode, the names are four (or five?) numbers, followed by a couple of random characters, so you get a filename like "0002HQ.avi" and "0003JM.avi". That works fine, *unless* that first random character is a number instead of a letter. That can throw everything off.
For example, you could have:
0001UU.avi
0002JL.avi
0003M5.avi
00041R.avi
0005S2.avi
That would be a five-clip sequence, recorded in sequence, and that's how they would appear if you sorted them by date.
If you look at the numbers, you can see there's four numbers, in ascending order...
0001UU.avi
0002JL.avi
0003M5.avi
00041R.avi
0005S2.avi
However, that's not how Premiere would show them in the bin. It'd show them like this:
0001UU.avi
0002JL.avi
0003M5.avi
0005S2.avi
00041R.avi
It gets "0004" messed up, because the first of the random characters (the "1R") is a number. So premiere sees it as if it's this:
00041R.avi
It thinks it's clip 41, instead of clip 4.
It's a problem, and I've asked them to consider updating the firmware to prevent that first random character from ever being a number. Until then, the way to keep 'em sorted is to use the recorded time & date, instead of sorted by filename.
I am lucky enough that I have the time date stamp burned into the image. I feel bad for all others. (but I doubt many people are shooting in DV) Other thing is I tend to use my Firestore files vs. the camera's SDHC card files.I have requested that this issue be fixed via a firmware update. Of course, I have no idea if the company will actually do so, but I can see it as being an issue and I think it would be good for them to fix it.
