Hello all... first post. Hope it's appropriate to start off with this type of query! I'm a professional videographer... primarily do weddings. I've used the Canon GL2 in my 8 years in business. I get great results with the camera but am ready to make the jump to the HD realm. I've narrowed my search down to two cameras... the HMC40 (of course) and the Sony FX7. I'm stuck between the two because they both have their plusses and minuses. The Sony is very familiar in size and style to the GL2. LOVE the zoom functions on the handle... something I utilize quite a bit. But, the HMC40's compact size would work well with the handheld steadycam for some interesting shots, shoots in the different formats including 24p, and the biggest interest, flash card recording.
If anybody could answer some questions for me, it would really help with my decisions.
1. Can the zoom controls on the HMC40 be set to different settings? IE- My GL2 allows the zoom controls to be set to several different zoom speeds, from 'really' slow through to 'really' fast. Can this be accomplished with the HMC40 with the grip zoom AND the screen zoom?
2. How would the widest zoom angle on the HMC40 compare to the same wide zoom on the GL2? It would be imperative to have a similar range of field covered with the HMC40.
3. I saw the manual for the HMC40 and it says that for mac only Intel based computers could be used for NLE. Is this really true? Can't you just transfer the video files over to say an Intel based mac (I have two Intel iMacs) in FCP, then save the capture files to an external firewire and then transfer them to a G5 running FCP for edit (I also have two G5's).
4. Regardless of #3 above, how is the transition from DV tape to this new format? What is the footage saved as in FCP? DV stream? MPEG? MOV? A big part of my editing routine is to locate the DV- Start/Stop points on DV tape footage imported into FCP. Does the files the HMC40 would provide allow those same start/stop points to be found for easier editing?
5. How would the on-board camera mic on the HMC40 compare to the on-board mic on the GL2? In some shooting situations, I'm happy with the on-board mic on the GL2 and would hope for the same in my new camera.
6. And finally, how reliable is this new format? Doing mostly weddings, I'd dread having a card malfunction and losing a client's "I do's". Any other folks using the HMC40 for weddings? Can the tapeless format be trusted?
-In a nut shell, if I were to invest in the HMC40 as my replacement for the GL2 (would be getting 4 cameras), I know I'd have to invest at least an additional $240 for the 32GB cards, per camera, with a couple back-up cards. But that roughly $1500 investment would pay for itself in a couple of years w/o having to buy DV tapes anymore.
-If I knew the zoom's on the HMC40 can be set to one speed (primarily super slow for nice fluid zooms), especially the grip zoom, that would be a huge plus.
-If the widest angle on the HMC40 is not similar to that of the GL2, I'd be forced to get wide angle lenses (another $1000 for all four cameras).
-Finally, and probably my biggest concern, is being able to edit "as usual" in FCP w/o any issues. If that's possible after saving the files to a scratch disk, I'd be a SUPER HAPPY CAMPER!
However, if I find I need wide-angle lenses for all four cameras I need, the grip zoom on the HMC40 can't be set to one nice super slow zoom speed (not variable), and the editing in FCP can be problematic depending on the system set-up, I'd probably be better suited with the FX7 for now. The zoom speed is a huge factor as I 'shoot-from-the-hip' a lot and it's not easy to control the variable zoom that way.
Any input would be greatly appreciated!
