Many moons ago I used to use a Canon XL1 to shoot weddings. Well when I recently bought my new HMC40 the first thing I did was compare it to my XL1. 0DB on the XL1 was pretty much equal to 12DB on the HMC40. Now in terms of numbers this may seem pretty freaky but in reality in terms of noise they are much closer then you would think. The Canon XL1 maxed out at 12DB of gain and it was pretty darn noisy. 24 DB of the HMC40 pretty much matched the brightness to 12 DB on the XL1. Both were noisy of course but pretty equal. I say this because the XL1 has been used for tens of thousands of weddings around the world. Sure it was a bit dark compared to some other cameras but it was used to great success. I personally have shot dozens of weddings with it.
So 12 DB on the HMC40 is going to have a tiny bit more noise then the XL1 at 0 DB but at 24 DB the HMC40 is pretty equal to the XL1 when the gain was maxed out at 12 DB. Now perhaps this still isn't acceptable to some people but it is what it is. Just keep in mind that this level of sensitivity was ok at one point in time. If you down convert to DVD the HMC40 will look even better and I consider the HMC40 down converted at 24DB to look much better then the XL1 at 12DB.
Now perhaps to me this level of camera has always worked well because I always use lights. Good video needs good lighting and ambient lighting just will never do it. There is a good reason why movies look the way they do and it has nothing to do with the framerate or aspect ratio. I would rather see more videographers use cameras like the HMC40 with a good light kit then continue to see people use cameras like the Sony EX1 with no lights at all.
The XL1 (1/3") is a 12 year old camera. I want a little better performance in a current camera than a 12 year old model.
All the latest 1/3" cameras are far more sensitive than the 1/4" HMC-40. If you are going to deliver a wedding video product on par with the rest of the current industry, you need a 1/3" sensor camera or better.
Thank you all for the input!
Basically I have $1000-$1200 left to spend. I plan on purchasing a Libec 38M (http://www.bhphotovideo.com/c/produ..._LS_38M_2A_Professional_2_Stage_Aluminum.html). I've used one in the past and for the price it should be just what I need.
I could rent some accessories for the first couple of weddings. I know I need some kind of steadicam system, lights, and a better microphone kit. How would you spend the $1000-$1200 to get the ball rolling? This is of course referring to my gear budget, not my advertising/business budget. Thanks!
