BobDiaz
The Professor
My Test Results
My Test Results
I was going to start a new thread, then I remembered we had this one already, so I'm posting images from the Century 0.5x Wide Angle Adapter.
SUMMERY OF TESTS:
While you can zoom into the image up to about 52 to 53, the corners of the image go soft. The more you zoom, the worse it gets. You might be able to do a zoom 10, but beyond that, it really gets soft in the corners. Just use this adapter at the widest angle setting for sharpest results.
At close to wide open at the widest setting, you can see a bit of softness in the corner. (Look at the grass in the lower right corner.) As you close the iris to F4.5, it's not bad and by F10.5 it looks normal.
F10.5:
F4.5:
F1.9:
Bob Diaz
My Test Results
SUMMERY OF TESTS:
F10.5:
F4.5:
F1.9:
Bob Diaz
