Im looking to upgrade from my dvx
both cameras are around the same price on ebay
but which should i shoot for?
alright so to get the all the benifits get a hvx for around 2.2k oram i getting it switched n should go for the hmc for 2.2???
If you're comparing the HVX-200 to the HMC-150--HMC-150 wins flat out. It has a faster lens and is sharper.
HVX-200A vs. HMC-150....tougher to call. Depends what you're doing and what you need. Picture quality, they're both pretty similar that the average person probably couldn't tel the difference between the two of them.
The biggest separating factor is recording media and codec. Plus, the HMC-150 can't record SD footage, doesn't have variable framerates (it has 60p, but no intervelometer functionality), and doesn't have a 4-2-2 color space.
You need to decide what you want and what works best for you. If you don't need the tape deck of the HVX, I'd suggest going with the HPX-170.
But it doesn't do variable frame rates, it doesn't record 4:2:2, and it doesn't record standard-def, and it doesn't have a DV tape drive; the HVX has all those. So you can't just declare one or the other the winner, only the prospective purchaser can do that, after evaluating his own needs.If you're comparing the HVX-200 to the HMC-150--HMC-150 wins flat out. It has a faster lens and is sharper.
