HMC-40 vs. 1 chip consumer cam
Martin Koch
After reading this very positive review I became very interested in the HMC40 (or HMC41 in my part of the world).
I own a Canon HF100 and I can't say that I'm overly impressed with it's image quality. It's good but not impressive. Now I found at least two postings where people actually prefer the HF10 / HF100 over the HMC40 for its colors or image quality. How can this be?
The HF100 has one single 1/3.2" chip so it can't be full raster HD and it's chroma subsampling is interlaced. I see e.g. sawthooth artefacts at all edges of red colored objects.
The HMC40 on the other hand has RGB information for each and every of it's 1920x1080 pixels and as I learned from the review above progressive chroma subsampling. It should deliver stunning highly detailed images.
I looked at several HMC40 samples at Vimeo but couldn't find an original clip download that was shot progressive. So far my impression is (from judging those Vimeo clips) that the dynamic range is not great and that the colors look muted and pale.
So what do I want to hear now? Please tell me that the HMC40 in good light is far ahead of a HF100. :dankk2:
I believe an HF100 actually has a full raster chip (2 megapixel). It's not bad at all for a tiny consumer cam. My brother has one, and the footage he has sent me is quite respectable. I seriously doubt it could outperform an HMC40 though (in any lighting conditions). It uses a single imaging chip, that is slightly smaller than 1/3". The lower maximum bitrate (only 17Mbps), all by itself, almost assures that the image couldn't be quite as sharp.
It's possible that the newer HF S100 (or equivalent HF S10) might barely outperform an HMC40 under some circumstances, from looking at the comparison of HF S10/S100 vs HDC-TM300/HS300, at camcorderinfo.com. I believe the TM300/HS300 uses the same imaging block as the HMC40, although my guess would be that the better CMOS imagers rolling off the assembly line are probably cherry-picked to go in the HMC40s (would be crazy for Panasonic to do otherwise). I believe the surface area of the single imaging chip in the S10/S100 has close to the same surface area as the three imaging chips in the HMC40 combined. Effective resolution coming out of either imaging block really should be fairly close (single 8 megapixel imager vs three 2+ megapixel imagers).
I've got an HMC40, and certainly don't find the color weak. Color is quite adjustable with the HMC40 (far more so than any consumer camcorder I'm aware of), to get the look you want.
The image, in adequate light, is tack sharp (impressed me right out of the box with the first test clip I shot, without even knowing the camera at all yet). It wouldn't surprise me at all, if footage from the HMC40 (properly shot, in ideal lighting) cut well with EX1 footage. 24p and 60p footage is recorded as true progressive video, not wrapped in a 60i stream (which you noted gives you the crappy interlaced 4:2:0 color). I believe 30p is wrapped in a 60i stream though.
The HMC40 is not nearly as bad as I thought it would be in low light (within reason, considering that it is a 3-1/4" chipper, of course). The gain is surprisingly clean, which makes a real world difference. Even 12dB can look pretty good - crank an XH-A1 to 12dB and it looks radio-active by comparison.
Martin,
I can't speak for the HF100, but the color saturation, temp, etc.. can be adjusted to taste via Scene File settings on the HMC40.
I shoot all my HMC40 clips in progressive mode and am very pleased with the result. With more experience and experimentation I expect there will be little the camera won't do for me.
Good luck with your research,
Dan
Thanks for the reply Robert and Dan.
I don't think the HF100 is "full raster" since it has to waste 3 pixels of its sensor to build up 1 actual RGB output pixel.
here i think is the bottomline
both probably has almost the same picture quality & low light
except hmc40 has:
- professional controls
- 24p, 30p, 60p @ 720
- 24p, 30p, 60i @1080p (native, no pulldown)
- costs more.
It's not quite that simple. There are more green "pixels" (sensor wells, if you will) than red and blue ones. While raw unprocessed output from the sensors is essentially RGB data, images are recorded as 4:2:0 YUV (1920x1080 luma resolution and 940x540 chroma resolution). I don't know the math behind the interpolation (aside from loosely). I'm also not entirely sure how "effective pixels" are actually counted (methodology) by the manufacturer, when declaring specs. (Those are things I've been wanting to look into further, but may never get around to.) If they were counting each sensor well on the imager as a pixel though, a 2 megapixel chip would be pretty low res. I believe the "effective pixel" count is essentially in terms of luma resolution, but I could be wrong there.
except hmc40 has:
- costs more.
I have an HMC40. I also have an HV20, which reportedly is fairly comparable to an HF100, for image quality. I don't have an HF100, but my brother does. I've seen some footage from it. It's not bad (and does seem roughly equivalent in quality to the HV20). From what I've seen, the HMC40 pretty much mops the floor with either of the aforementioned camcorders. It certainly shoots a sharper image, and does perform better in lower lighting conditions.
I'm still learning the HMC40 (have had it about 2 months). It's a serious camcorder (quite robust manual controls really), that can shoot stunning images. From what I've seen, I'm quite confident that the HMC40 can hold it's own (with adequate lighting) with camcorders costing well more than twice as much. I really do think you could put it next to an EX1 and likely get pretty comparable image quality (again, with adequate lighting - obviously, an EX1 will cream an HMC40, shooting with less than ideal lighting).
... the HMC40 pretty much mops the floor with either of the aforementioned camcorders. It certainly shoots a sharper image, and does perform better in lower lighting conditions.
That's exactly what I was hoping to hear :happy:
The HV20 by the way has a better image than the HF100. At least thats what I've heard. If it's also beaten by the HMC40 then all is well for me.
Thanks also for the sensor explanation. All this de-bayer science goes over my head and just leaves a bad feeling. I like it more straightforward like 3CCD or Foveon. This I can actually understand.
3 CCD (although all the camcorders mentioned here use CMOS imaging chips) may seem more straight forward (conceptually), but it's actually more complicated than single chip imaging (at least from a hardware perspective). Both approaches have advantages and disadvantages.
Come to think of it, working out good de-bayer algorithms has got to be easier than getting pixel shifting algorithms (for 3 chip imaging) right.
My experience with the smaller Canon consumer cams (I own an HFS10) is that while the picture id quite nice, the controls are way too annoying for any serious use. I'd think that even if picture quality is same between the HMC40 and the Canon, (from what I have read they are pretty close) the Panasonic has such better manual controls plus XLR option, that I would pay the extra and get the Panasonic based on that alone.
i think pixel shifting only applies to ccd
cmos have more pixel density thus can offer full hd at smaller size (albeit sacrificing low light sensitivity)
im actually wishing for a 1/3" hpx170/hmc150 like cmos cam from panny
I'd rather shoot with the HMC40, but I sure wouldn't mind having an S10. It is nice to have a little tiny cam at least capable of shooting a decent HD image, that you can take with you pretty much anywhere really easily (even if it's pretty limited for manual control - as long as you can at least lock down the exposure, including gain, and WB, otherwise it's just pure junk). The little Canons can do that, and that instant auto focus actually works pretty dang good. I've got a little HV20, that's come in real handy at times (and recorded some priceless memories with it really). From what I've read, that S10 would be a nice little step up. When they drop in price (give it a year), I'll probably keep my eye open for a nice deal on a good used one. The HMC40 is a small cam, especially for what it can do (pretty amazing really), but it's not quite as easy to just grab on the way out the door in a hurry, as the itty-bitty consumer cams are, and I don't worry nearly as much about breaking an HV20. I'm sure I'll wind up shooting a few more tapes with the HV20 this year.
As I understand it, to actually get maximum effective resolution recorded, you really need to start with an image that's at least a little over-sampled (more effective imaging chip pixel resolution than the number of pixels actually recorded). I believe there is indeed benefit to the final recorded image, using pixel shifting with imagers that are close to "full raster" or a little higher (like the HMC40 with CMOS chips that have about 2.5M effective pixels). There's nothing about the nature of CMOS chips that precludes using pixel shifting technology (which basically boils down to relying on what you could loosely think of as getting more resolution out of the imaging chips by using some pretty fancy math, than by simply counting each dot on the imager as just one pixel).
Think of it this way. If you want a real sharp picture, you start with a bigger one and shrink it to make it really crisp.
Even if the chip quality rendered identical image quality, the better manual controls and audio potential of the HMC40 would make the HMC40 a much better cam for pro use.
Grant
Consumer camcorders can be useful for some professional purposes, but the HMC40 is indeed a camcorder with controls worthy of calling it a multi-purpose pro camcorder, and the image quality (with reasonably adequate lighting) is downright superb for a camera anywhere near (or even two-three times) it's price.
In some ways, the HMC40 is definitely better suited for professional purposes than much pricier camcorders. You can't find a more portable, light (read easy to shoot hand-held) camcorder, with reasonably pro-level control, that can shoot a better image. It can go places where the size and weight of bigger cams would simply be a real liability. Remove the handle and perhaps replace the lens hood with something a bit plainer looking, and you can probably go far more unnoticed in places where a bigger cam will get you undesirable scrutiny too (read killer quality stealth cam!).
I don't know that putting the optional XLR adapter on an HMC40 gives you a whale of a lot better audio than crazy-gluing a BeachTek to the bottom of an S10 (or whatever). Camcorder audio circuitry just isn't what you would call high-quality to begin with.
