bradywurtz
Ok, so i've owned the HMC-40 for a year or so now and got it and realized there is no ND filter on it. big upset.
then when i recently looked on BHPhoto, in the description for the camera, it says it has an auto on/off nd filter built in. and then doesn't describe it at all really
then i talked to someone on live chat for BHPhoto and they said they're not positive about it, but apparently when you lower the iris, it activates the nd filter and adjusts accordingly as you lower it
i found that this is completely false. as you lower the iris, it starts slowing down your F stops, and it displays so on the screen.
this is NOT the same as using an nd filter. if i want a real shallow depth of field, i need the fstop to be real low like 1.8 or something. but if i need it to be darker cause i'm outside, i throw an ND filter on it so that i can cut down on the light, but not lose my depth of field.
but on this camera, the only option i have if it's to light outside, is to keep dropping my f-stops down lower and lower, and i can actually see my depth of field becoming bigger and bigger.
i focused on a window frame in my house and had a tree unfocused in the background from across the street. as i start dropping my f-stops down to 10 and further, i can see that the tree on the other side of the street becomes more and more in focus.
bottom line and question:
is there something i'm missing on how to activate this 'Auto on/off ND Filter'? or is Panasonic just flat out lying to us. In which case, I feel like if I call them up, i should be able to get a full refund from them for lying.
