Lee Wilson
And all I was saying is that Vegas allows sliding video by samples, if you disable quantize to frames.
I understand what you said about disabling "quantize to frames" (I think you already said that in an earlier post).
I am not sure I made myself clear (too many numbers!) - let me try and explain what I mean more clearly.
My point is that the idea that you can slide video by samples (or anything less than a whole frame) is merely a conceit within the application, you can't really do it with video footage.
After all what would the result look like (assuming we are blending two images as in a HDR application) - or what if we were simply editing between the two tracks with a simple cut, would track B come in a little earlier when we cut to it (if we have moved it earlier by a a few samples ?)
Of course track B would not (could not) come in earlier (even by just a few samples).
Take a look at this, I have moved track B earlier by less than a whole frame, now let's imagine the output from a 50% / 50% mix between the two tracks, what would you expect frame 147 to look like ?
Or if you were not blending two frames and simply doing a hard cut, what would you expect to see when cutting from frame 147 of track A to frame 148 of track B ?
