Hi-hat boards are ready...
Erik Olson
Unscripted Mod
Staff member
All,
The first batch of hi-hat boards are done. As soon as my digital camera shows up on Sunday, I'll get some pictures posted on my site.
16 x 16 x ¾" - http://www.expeditionfilmpartners.com/store/dept/products/p200.htmlJr. Hi-Hat Board --- Why make it smaller than the traditional Hollywood hi-hat board (available below)? Well, it is a lot cheaper to produce - we get almost double the cuts from a single sheet of plywood when compared to the 18" standard! For small cameras like a stock DVX or Sony VX/PD et-cetera, the 16" board is plenty stable - even on grass. Each cabinet-grade board has 1½ x 5" handles on two ends and a 5" hole dead center for threading your own Mitchell mount or claw ball from underneath. Shop birch or maple, sanded with two coats of clear water-based finish. $24 each + S/H (USA)
18 x 18 x ¾" - [url="http://www.expeditionfilmpartners.com/store/dept/products/p100.html"]Standard Hollywood Hi-Hat Board[/url] --- Each cabinet-grade board has 1½ x 5" handles on two ends and a 5" hole dead center for threading your own Mitchell mount or claw ball from underneath. Shop birch or maple, sanded with two coats of clear water-based finish. $30 each + S/H (USA)
18 x 24 x ¾" - CamShuttle Hi-Hat Board --- Each cabinet-grade board has 1½ x 5" handles on the ends and both sides (four total) and a 5" hole dead center for threading your own Mitchell mount or claw ball from underneath. The CamShuttle boards will mount to our metal 1" subframe for use on 1.900 O.D. aluminum speedrail. Two (2) CamShuttle boards can be combined into a doorway dolly using our 1" subframe for use on standard 24½" dolly track. Shop birch or maple, sanded with two coats of clear water-based finish. $40 each + S/H (USA)
(CamShuttle trucks, subframe and suspension fittings available 5/05)
Appleboxes - We're tooling up again to produce Applebox Classic (ACX construction) and MatteBox (MDF construction) for process work. Prior to relocating from SoCal to NorCal and now to North Carolina, we produced all the appleboxes for Fox and Universal Pictures Studios. We will be ready by summer, and should be able to beat just about everyone out there with our dedicated production line.
$28 Full (ACX or better)
$26 Half (ACX or better)
$24 Quarter (ACX or better)
$20 Pancake (Shop Birch / Maple)
$24 Jr. Hi-Hat Board 16x16x3/4" (Shop Birch / Maple)
$30 Hollywood Hi-Hat Board 18x18x3/4" (Shop Birch / Maple)
Contact me with any questions or special needs... we can turn custom work usually in less than one day (ready to ship)!
products@expeditionfilmpartners.com
Cheers,
Erik Olson
Overland Films
Photo of Hollywood Hi-Hat Board...
This is a picture of the Hollywood Hi-Hat Board (measures 18"x18"x¾"). Our Jr. Hi-Hat Board is suitable for use with a standard DVX100(a) or VX sized camera. If you plan on adding iris rods, DOF converter and mattebox, we strongly recommend using the larger Hollywood Hi-Hat Board.
Both feature a centered 5" hole for threading your Mitchell or clawball high-hat from underneath and a 1½"x5" slot at either end for easy transport.
email us to order: products@expeditionfilmpartners.com
This is the Overland Grip Jr. Hi-Hat Board pictured with the new Bogen hi-hat. 16 x 16 x ¾" is slightly smaller than the Hollywood Hi-Hat Board, but not discernably less stable with a small camera.
Overland Grip Jr. High-Hat Board
Thanks for checking it out!
