OregonDank
ok sorry about the delay...start off with some 1/2" pvc that comes on a roll like this:
then you cut a length of pvc (i just kinda eyed it) and stick a male-to-male connector piece in that sucker and make a ring...you could use pvc cement if you have it but i just used superglue and a couple of wraps of gaff tape at the seam and its just fine...here's a pic with the aluminum angle-iron used as the crosspiece:
https://owa.ad.cocc.edu/exchange/ss...18C0-4a97-9AF2-036E93DDAFB3/sam3.JPG?attach=1
after you have a ring, wrap it up in padded griptape made for mountainbike handlebars...i just grabbed some from REI...after the ring is wrapped good (the sides especially) drill some holes in the aluminum (for a quick release and for attachment to the rig) and use conduit clips to hold the bar to the ring, like this:
https://owa.ad.cocc.edu/exchange/ss...18C0-4a97-9AF2-036E93DDAFB3/sam5.JPG?attach=1
then you slap a QR plate on there (or you already have) and you are pretty much done...here she is finished:
https://owa.ad.cocc.edu/exchange/ss...18C0-4a97-9AF2-036E93DDAFB3/sam6.JPG?attach=1
if it had a manfrotto plate it would be as good as the real thing only lighter...i'll be back in a minute to put up some more pics - any questions fire away...
https://owa.ad.cocc.edu/exchange/ss...18C0-4a97-9AF2-036E93DDAFB3/sam3.JPG?attach=1after you have a ring, wrap it up in padded griptape made for mountainbike handlebars...i just grabbed some from REI...after the ring is wrapped good (the sides especially) drill some holes in the aluminum (for a quick release and for attachment to the rig) and use conduit clips to hold the bar to the ring, like this:
https://owa.ad.cocc.edu/exchange/ss...18C0-4a97-9AF2-036E93DDAFB3/sam5.JPG?attach=1then you slap a QR plate on there (or you already have) and you are pretty much done...here she is finished:
https://owa.ad.cocc.edu/exchange/ss...18C0-4a97-9AF2-036E93DDAFB3/sam6.JPG?attach=1if it had a manfrotto plate it would be as good as the real thing only lighter...i'll be back in a minute to put up some more pics - any questions fire away...
