Help!!!
Justin Marx
I know I shouldnt post this here, But it's an EMERGENCY!!!
Got a buddy that made it to the ONT THE LOT SHOW (SPIELBERGS NEW REALITY SHOW) .. Just shot a short for the show in 480 24P mode (recorded on P2 card) (we only have a day to edit)
WE REALLY need help.. We imported the clips and each one needs to be rendered (RED LINE RENDER).. OR we change the sequence settings (below) and then we dont need to render, but the clip has a border around the entire frame (still letter box, just a border also around the LEFT and RIGHT side of frame)
1-Is it possible to import a P2 clip and not import it properly?
if YES
How do I need to RE-import these clips? what settings? we've tried many and..
2-when imported into the timeline they have these horizontal lines on them..
What should my sequence setting be set to?
I have it set to: DV NTSC 48kHz - 24
Capture was set to the same.
PLEASE HELP!!
EMAIL ME@
SHOWLACE@AOL.COM
or on here..
THANK YOU!!!
did you shoot it in DVCPRO 50? if so, then you need to use a different timeline setting: DV 50... Just make sure your timeline settings are the same as what you shot, then you should be able to edit in real-time.. Make sure you switch your timeline to progressive as well....
