magicdavek
Last night, I discovered that my DVX100A is stuck in it's time code. I can't play anything back in VCR mode. I tried a few tapes, and the time code is stuck at zero. I can see that the tape mechanism is turning the tape, and I can hear it, but the screen is all blue. When I try to play back, an asterisk * appears after the TC at the top of the window.
Just before I discovered it, I had the cam hooked up to Final Cut Pro and I was importing footage.
I turned it off and on a few times, twice with a long time in between (a few hours). I popped out the battery all night, and started from scratch - still the same. I tried with a new blank tape and existing tapes.
Help! I'm in the middle of a project and need the cam. The manual was not helpful in this regard.
