FINAL DRAFT: Help with Final Draft (I'm doing something wrong obviously)
Oller Visuals
I've imported my screenplay from Word into Final Draft as an unformated .txt, and everything looks great until I start changing stuff. When I select "elements", more than just the selected text moves around. FD version 9.0.2 (also, I appear to have clicked something that changed the UI to some older style, not sure how to change it back).
What am I doing wrong? Never used Final Draft before, and haven't found the answer to this issue in tutorials either. Video showing the problem:
https://vimeo.com/251122803
(password: test)
Update: What appears to be working is selecting a large chunk of text (not single lines), and then set them to the same formatting (eg. "action"), and then after that fiddle with individual lines, so that FD has its own "default" formatting to begin with. Still odd though, but there's probably something still stuck from Word... whatever it is, as far as I know unformatted .txt shouldn't hold any extra data? (There is a separate option for keeping line breaks when exporting as .txt).
I know this is old but just in case someone else has the same problem.
It really is pathetic. I'm using FD 10 and importing text from a google docs file comes out as crap even though I used a formatting I thought it could easily (or mostly) figure. Conversely, Highland 2 did a very good job.
I found in FD I had to have a blank line between each element, then select the element type from the bottom left corner. So I would hit enter a couple times after character name, then the parenthical, then the dialogue and then format each.
What a piece of ##$%$#% program.
