giacomino
Can someone please tell me that has gone through this already?
1) i need to give someone an uncompressed quicktime movie file on a dvd that i edited on fcp 6.05.
segment is shot in 720 30pn from an hvx200
compression is dvcpro hd 720p60
frame is 960x720
in the past i would just export using quicktime conversion; under options dvcpro hd 720p60 or i would export to h264.
after reading more on this forum re compression(s) i hear everyone saying not to use quicktime conversion....
so i am now confused. also, i noticed when i export useing dvcpro hd 720p60 compression the quality is listed as medium???
also, when exporting and your frame is 960x720 do you keep it the same or do use 1280 x720?
and when i export using quicktime/make movie self contained, after exporting, do i open with quicktime and then export? isn't that just doubling your work if it ends up still being a quicktime movie
getting more confused...can someone give me some insight?
any advice would be great.
thanks, jimmy
frame is 960x720
thanks, jimmy
