I recently purchased a used FS100 to go tape-less for my DVX100A and can't seem to get it to function properly. I set everything according to the manual and when I press the record button on the cam it triggers the FS100 to start recording but when I press the record button again it has no effect. I realize that the unit is intended for HVX200 but people have been using them with other Panasonic camcorders such the DVX100's. My question is, is there a special way for it to work with out having to place a tape in the cam? The hole point of buying the unit was to eliminate the need to use tape. Here are the settings I used to for the camcorder and FS100:
1. Set the DVX100A to - other functions - DV control - both. Set recording setup - UB Mode - FRM.RATE
2. Set the FS100 to - RECORD - NORMAL - HDD MODE - DVCPRO/DV REC. DV FORMATS - QUICKTIME. CONTROL - TAPELESS.
Now I have access to a DVX100B and it works without a tape but the DVX100A you have to put a tape in order for it to work - strange. Any help or input would be appreciated.
Thanks-Sal
Thanks-Sal
