Help With DVCPro50
Alex 3D
I have the awesome HVX. Well, I rented an 8 GB P2 card for a test run (we've been shooting miniDV tape) and I like it a lot. I'm shooting mainly local car dealer stuff outside, showroom. We're building a nice stable of Ari and Keeno lights.
My end target is burning a BetaSP tape to broadcast and cable-NTSC. I set the Recording Format to 720P/30P. THE 480i Rec Mode automatically switched to DVCPRO50. I'm assuming this means I'm shooting Pro50 at 4:2:2 color (gee, can you tell I'm new at this?). After I import to Final Cut, the format says "DVCPRO HD 720p60." I'm also getting 59.94 fps on these clips. I'm guessing that has to do with the progressive deal.
I think I need to order Barry's book, assuming it's more real-world situations. Thanks for any help.
--Alex
720 and 1080 always use the DVCProHD codec. DVCPro50 is only available in SD mode.
Thanks for that tip THoff. So the settings below fall into the SD--DVCPro50 range. Knowing what I shoot (see previous post), what is the best quality choice for me to experiement with? I don't have the cam with me at the moment.
480/60i
480/24p (over 60i)
480/24pA (over 60i)
480/30p (over 60i)
Each of those recording formats is diffferent, but there is really not a "best" setting. Here are some basic guidelines.
Target: NTSC broadcast only, with film-like motion (narative/dramatic show) you might use 480/24P DVCPro50.
Target: NTSC broadcast + deploy versions on the web, with film-like motion (narative/dramatic show)480/24PA DVCPro50.
Target: NTSC broadcast + Web, with a more realistic/video look then stick to the 30P (if going on web) or 60i for standard NTSC.
Keep in mind that it is a lot easier to create an interlaced version of a program from progressive footage, than to do the opposite. So unless a producer only wants 60i, I always will shoot progressive.
Try them out and see which one suits the look you are going for.
Why would you choose 24P over 24PA? There's no reason to shoot 24P over 24PA,
since 24P only creates unnecessary frames during the pull-down procedure. Not only
that, you have to go through CinemaTools if you shoot 24P to reverse-telecine in order
to edit on 24 fps (exactly 23.98). Whereas, you just click an option in FCP during the
capture for the materials shot on 24PA.
Nook
