thomthomproductions
I am attempting to capture some footage from a projected super 8mm film.
Obviously I could simply send it off to be scanned! but I still like the "projector" feel - the sound the atmosphere - which is critical for its final use! (+cost!)
Just looking for some hints from the forum on what aspects of the AF100 I should be focusing on for best capture- has anyone done this before?
For the record I am using 18 fps projection (at 1 meter distance) from a super8 mm film (kodachrome and Etachrome)
I am using the Voigtlander 25mm lens.
So I am asking myself:
If I am filming film should I use AF100 "film" settings? or "video" as the subject already has a film feel! + what settings are relevant to this? (obviously there are a lot to play with!)
What frame rate? or should I focus on shutter speed or both?! (thank goodness for the F0.95 lens!)
I would like to "control" the flicker (not necessary to eliminate it
Any help would be great - I'll post up you tube links as I go along if you want! (I have had a look around the forum to see is this has been covered but cant find anything - if I have missed a thread please advise!)
regards
Christopher
regards
Christopher
