Help with 16:9 footage!
Hi, Im having a problem with squeeze 16:9 footage in final cut pro. I capture the footage fine with the pulldown an all, and when I play the clip in final cut by double clicking the clip in the left browser it looks fine..heres what it looks like http://home.comcast.net/~streetsk8erdc/Picture_3.png
looks fine and dandy..BUT when I drag clip to timeline ..THIS is what it looks like in the preview monitor
http://home.comcast.net/~streetsk8erdc/Picture_4.png
it has some type of stretching on it and it does not look right...so then I thought maybe I need to change sequence settings to anamorphic, so I did that and THIS is what the preview monitor then displayed
http://home.comcast.net/~streetsk8erdc/Picture_5.png
stretched wierd! ...Can someone plz help me and tell me what im doing wrong? I imported same thing in a "widescreen 48khz " project in adobe premiere pro and it looked fine with no stretching. Another question, when im capturing 24pa anamorphic squeeze footage in final cut..do I use the pulll down removal option default? or do i edit it and add the anamorphic option to the removal option.
control click (or right click) the clip in your timeline and select "remove attributes." check "distort" and click "ok." perhaps that will work. or perhaps not.
