Robin Thomass
So now that I have solved most of my questions regarding PAL/NTSC and the ND filter being "stuck" I'm off to shoot an event this weekend and I need reassurance as I'm still not sure to use the HVX and favor my canon 6D instead.
First I want to know if this thread and warnings are still relevant : http://www.dvxuser.com/V6/showthread.php?118672-Proper-P2-Offloading-Procedure-For-A-Mac
I'm using Final Cut Pro X and I just tried uploading clips using the FCP internal import mechanics directly from the Cam (I don't have the card reader) and it worked just fine. But reading this thread made me nervous about using the HVX200 at all ! I just can't take any chance this weekend.
Also, I obviously want to shoot in 1080 but I don't know if I should do 1080i/60i , 30P, 24P or 24AP. I would like to minimize the grain and eventually slow down some clips I'm pretty sure that it's 60i I want, but maybe I should stick to 720p as i heard the HVX200 is not a native 1080 cam. I'm a bit lost really...
Also, if I shoot in 1080i/60i, what is the codec used and what preset should I use on my FCP project ? Will there be problems integrating clips shot with modern iphones and Go Pros ?
Thanks for all your help !
