HELP! problem with exporting AF100 material from Premiere CS4
mike9399
Hello,
i recorded with the AF100 in Full HD 25p mode (PAL country here), as i wanted to scale down some scenes i edited all in CS 4 within a sequence AVCHD720p25, all went good...just when i want to export at some moments the video stutters (like time displaced frames or jitter effect). The original mts files are fine and play smooth in external player, also within the premiere timeline when i do preview.
So something must go wrong during export. I tried several settings but still the jitter is there at certain moments. Anyone know about this? I need the final video just in PAL DV for a DVD and for upload to Youtube etc. Anyone can advise me export settings to try out?
The worst is that this project is for a client, and i don't know any way out in the moment....
It might be a good idea to render your files, by verifying the green bar at the top.
Also, it's safe not to have any blank video..Replace any blank video with "black video".
After that, launch Adobe media encoder (or export from timeline).
Use the correct preset, and adjust settings accordingly. There's a little flyout box on the right hand side. Make sure that "use preview files" is checked.
Thanks for the quick hint mate! Seems that you saved my day :) ...somtimes it is so simple and the operator is blind. So just in case anyone else would ever have similar problem: after setting keyframe distance (3) and activation of "use preview files" and "max redner quality" the jitter problem is solved.
