Hey guys, I was hoping someone could help me out with this problem. Today I shot some footage on 720 24pn...and I'm having issues importing the p2 into FCP. Any footage I have that is above 34 seconds in length, the P2 transferring progress bar doesn't change... and after about 5 seconds it stops trying to transfer and says the clip is qued. Then in the status bar, where the qued clips are placed in the bottom area of the P2 panasonic import section, a Red Octagon with a white exclamation mark appears. When I put my cursor over this symbol, a message pops up describing the problem saying...
Error: No Data
Meanwhile there is data...because I'm able to view the footage, and import it in Standard Def via the log and capture mode in FCP.
I know that this isn't an issue with FCP or the computers I'm using, because I tried to import the footage on two different computers, both of which have succesfully uploaded p2 footage in the past. I'm thinking it's either a problem with the card or the camera, most likely the p2 card.
Has anyone had this same problem occur? Or does anyone know about this problem I'm talking about. Any help would be greatly appreciated. I plan on calling the dealer I bought this from and Panasonic early in the week to see what I should do about getting this fixed (I still have 8 months warranty on it), but, I'd appreciate it if I knew more information about the problem before calling in so I don't get the run around from the people I call.
Thanks in advance for your help.
Error: No Data
