HELP!!!! No Headphone Output!!
  • Start date Start date
G
Guest
Guest
last week i had a shoot & i noticed that my headphones were not working with the DVX. the levels were moving, i had a slight hiss coming from the right side, but no audio.
i figured it was the headphones because they were pretty old and beat up, but i tried it again with a new, perfectly operational pair when i got home & got the same results.
could i have changed anything in the menus that could have caused this? also, i just started using a boostaroo audio amp on the shoot prior to this--could that have caused a mechanical problem in the camera? (btw, i have tried monitoring with and without the boostaroo attached, to no avail).
any help would be greatly appreciated.
Re: HELP!!!! No Headphone Output!!
Greets!
On the top of your cam to the left of your menu area, there is a place to adjust your monitoring level...try that out. I freaked out over the same thing about a week ago!
hmm... to me it also happened.. (or is it something else?!) no audio monitoring out of a sudden. but i just had to turn the camera off and on again and sound was back.
thanks for the tips, guys, but no luck--i turned the monitor volume all the way up & i've shut off & on many times (both AC and battery) to no avail. the sound comes through the internal speaker all right, but only a loud static hum through the right channel of the headphones and no audio whatsoever.
my guess is that the headphone jack is fried. i'll be pissed if the damn $20 boostaroo is what caused this.
should the warranty cover this or would i be better off just taking it to an electronics repair shop?
Warranty should cover it, and I cannot conceive how the Boosteroo could have done it.
