Barry Green if your out there please lend a hand. I did the crazy 2fps hack thing. It worked. See link: http://www.dvinfo.net/conf/showthread.php?t=66800
Got some fun footage out of it.
Only thing is that now my camera is a little crazy. Now I know this trick came with a set of warnings that qualify it as being a dangerous thing to do but, so far as I can tell I'm the 1st with some issues. Lucky me.
1st: Now this is a biggie. No working tape mode. When I switch to tape it remembers my variable frame rate settings (wouldn't that be nice) and doesn't record at all.
2nd: It seems that my settings are now saved with or without my memory card. Now correct me if I'm wrong but in the past when I turned my camera off and removed the sd card if would return to the factory defaults. Now it remembers the settings saved last on the cards as if they are the defaults.
3rd: is that the camera no longer displays time code , but instead some crazy gibberish at the top that flickers somewhat random characters. The clips actually do have time code but this bug is more of an annoyance.
I have since changed all of the frame rate setting to approved frame rates. I have reformatted the sd card. I need help. If anyone out there is have similar problems I'm ready to bond. If there is a way to reset the firmware or something please advise. Others beware...your camera is sensitive.
