Help color Problem!!
qap15
DVX100A, the color red is very much pronounced, how do i adjust the settings to get some increased amount of yellow?
Yes, the Panasonic cameras tend to make the reds a little hot. It's worse if the image is underexposed. Make sure you're using plenty of light.
You can also lower the chroma level some in the scene file -- though be careful with this.
ikander:
never tried anything with the white balance before, i'll check that out.
David: yes you are right, last week i used both my GH1 and the DVX and both produced the same hot red, at first i thought it was the tft screen, but when i placed both clips to the fcp timeline i got the same result.
I would like to produce the color near to what im seeing on the TV i.e a bit yellowish.
