R ReIs Well-known member Dec 14, 2009 #1 im looking for any suggeations for a HD monitor for the 300, i have around $ 800 and need some suggestions , i was considering the IKAN v8000p but came to learn that there is no way to use it in HD in conjunction with the 300.
john50t Member Dec 16, 2009 #2 I too have been pursuing this. For the HPX300, you need a at a minimum, a single HDSDI input on any monitor, camera mounted or other wise. The least expensive unit I've found so far is: http://www.manhattanlcd.com/product_p/7011.htm Also, check out this thread on the DVXUSER forum: http://www.dvxuser.com/V6/showthread.php?t=171096&page=4
F/VESCO Well-known member Dec 21, 2009 #3 You are not going to find much for $800. Spend the $$$ and get a BT-LH900
Z zeke Well-known member Dec 21, 2009 #4 Datavideo has a 7" HD/SDI model for under 1K USD. Does not have sdi pass through. http://www.datavideo.us/products/video-monitors/hd-monitors/tlm-700hd-7-hd-sdi-monitor.html goes for 849 at B&H http://www.bhphotovideo.com/c/product/621091-REG/Datavideo_TLM_700HD_TLM_700HD_7_SD_HD_LCD.html worth a look. Not sure how well they are in the field, but for indoor use they seem pretty good. My church bought 3 of them.
R ReIs Well-known member Jan 8, 2010 #5 i was looking at the datavid 7" , but what does not having the pass through entail?
