Help: Atomos Ninja Star powered w/ D-tap Dummy + Swit S-8972 battery?
aly324
Hello, I have to have equipment shipped to Asia right now for work and need to be absolutely sure before I odrer.
Can the Atomos Ninja Star be powered with a Swit S-8972 battery via the Atomos D-tap dummy battery plate? If so, what exactly is the power cable I need?
Many thanks!
The Ninja Star can be powered directly from a Sony NP style battery, which your Swit battery is. The Atomos D-tap adapter will accept 7.2 to 16.8 volts, so your Swit battery (7.2 volts) will work through the adapter as well. You will need a Swit S-7104 cable to connect the DC jack on the battery to the D-tap on the Atomos.
