Can't go wrong with the classic Sony MDR-7506...
I will 100% second Doug's recommendation of the Grado Labs SR80....
.... as Doug notes they're open-air so not ideal for noisy situations (or situations where you don't want others to hear your headphones).
are you guys using headphones for editing?
I have been advised in my ver beginning of editing not to do so.
My monitor speakers blow away any pair of headphones I've ever tried for editing and are less fatiguing. I only use headphones while editing when I absolutely can't run the speakers for some reason OR when I'm sound-testing a mix on headphones specifically. But... I do have some pretty high-end monitor speakers in a pretty well tuned room.
I've always been told you should mix on speakers and then check on headphones rather than the other way around because headphones tend to boost both low-end and loudness... meaning you'll often leave dialog a little too low in the mix because it's easier to hear on the cans.
FWIW, I also check my stuff on a crappy set of $10 computer speakers and a cheap-ish sound bar (which simulates stuff being played through TV speakers).
