C CK1 Active member Jan 26, 2009 #1 I need to find a work around. I've imported and edited a HDV project in Avid, but can not burn to bluray. Long gop and avid don't get along. Any suggestions? Thanks!
R RockmanX3 Well-known member Jan 26, 2009 #2 Maybe export the movie file and convert with an outside application?
C Christian m Well-known member Jan 26, 2009 #4 If you capture from an HDV deck to software only avid the capture and edit is native hdv mpeg2, unless transcoded afterwards. One suggestion is to transcode the entire sequence to DNxHD and then us a QT reference file for whatever authoring software you might use.
