I was thinking of getting the HMC40... instead I got myself a used V1U. It was almost an impulsive purchase, after I missed couple of good deals on XH-A1 because of my own indecisiveness. Anyway, the topic here is not about the camera that I bought, but about recording format and physical form factor.
My preferences are:
1. I prefer cheap tapeless (read: SD/SDHC or CF) to tape.
2. I have no real preference between AVCHD and HDV; despite that AVC can in theory be twice more efficient than HDV, in practice they look very comparable.
3. I want to watch my clips with realtime frame rate. I want to edit them in realtime too, even with filters and effects.
4. I don't care much about file size, but I guess I'd prefer to keep bitrate under 50 Mbit/s for space-saving reasons.
5. I don't care much about 720p vs 1080p as long as I can get "film-like" progressive (24/25/30) and "reality" progressive (50/60) frame rates.
6. I wish interlaced were dead.
After having the V1U for almost two weeks I can say that I don't hate tape, it does not make me cringe, I can wait 30-40 minutes waiting for video to be transferred to my computer. I don't shoot much. Still, tapeless is future.
HDV can look good. Older Sony camcorders, including the V1U, have worse codec than Canon cameras, so you can can spot macroblocks more easily, especially in busy scenes. This is not a defect of MPEG-2 per se, Canon proved it with the XH-A1, which wasreleased in 2006, but its video is on par with the newest Sony cams and I think it matches the HMC150 pretty well. So, I would put the quality difference argument between HDV and AVCHD to rest.
HDV edits much faster than AVCHD. I have a quad-core 2.2GHz machine. When I play an AVCHD clip in the Vegas timeline, it plays fine for about 15 seconds with 50% CPU load, then core temperature jumps to 65C, the fans wind up, the CPU speed is throttled down, and I get a noisy computer with 100% CPU load and 5 fps playback. Nasty. I was not able to find software for controlling CPU fan, basically to turn the fan all way up and keep it like this, and I could not find a way to turn CPU throttling off, I set Windows 7 power profile to 100% performance, but this does not help much. I guess if I put my computer outside (it is about 50F outside in the nighttime) or put it on ice, or add a couple of huge fans to the computer case, I can achieve realtime AVCHD playback in Vegas. Still, when I add effects, even simple ones like levels, the frame rate drops, and there is a pause in cut points even without effects added (damn you long-GOP AVC). So, to make sure my cut looks clean I have to render small pieces with the cut in them. Please, do not recommend using Cineform or other intermediate codec, I want to work with original files. With HDV it is almost like editing DV on my older 2GHz Athlon 32. Vegas is fast, responsive, does not slow down much even with effects, and cuts are almost as fast as with DV.
I hate those cliche statements like "AVCHD is not ready for primetime", but seriously, it is still a pain to edit. Maybe if I've got an 8-core c7 machine it would look alive... But considering that there are very little visual differences between HDV and AVCHD, I would prefer having HDV video on solid state media. Um, no, I don't want XDCAM or XDCAM EX with its expensive media and equipment. Basically, I want something like the HMC150/HMC40 that encodes to MPEG-2, not to AVCHD. OR, something like a Sony's CompactFlash card recorder, which is not a tack-on to a tape-based camera, but is main recording media, without tape transport whatsoever. I am not sure what format these external recorders use, I think they just record raw MPEG transport stream instead of wrapping it into MXF like XDCAM does. This is fine, this would work for me.
And here are my attempt to look into 2010:
I don't think that Panasonic will enable MPEG-2 recording onto SD cards. After all, AVCHD officially does not support MPEG-2, though many standalone players accept MPEG-2 payload with AVCHD file structure. So, consumer/prosumer models from Panasonic will stick to AVCHD. AVC-Intra is even more resource-intensive, so I am not expecting it on lower end models. I do not expect a successor of the HMC150 to use DVCPRO HD either, this would ruin P2 business for Panasonic.
Situation with Sony seems more promising. They continue relying onto MPEG-2, which now seems to me like a brilliant strategy. HDV/XDCAM/XDCAM EX - all use MPEG-2. Third-gen models already come with bundled CF recorder. It does not record in XDCAM format, but users seems to be pretty happy with bare M2TS. I expect next year's Sony lower end models to ditch tape transport and replace it with solid-state media. Which one: CompactFlash or MemoryStick? (obviously not SxS, too expensive). I believe that Sony will use CF media because it is more upscale than MemoryStick and better fits prosumer models, and is not too proprietary to portray Sony as overly greedy. Will Sony allow recording at higher than 25 Mbit/s bitrates? I don't think so, this is XDCAM EX terrritory. Anyway, with good tweaking, MPEG-2 can look good and it is much easier to edit. It would be fun if Sony flanked Panasonic with well-supported easy-to-edit tapeless format. Their decision to keep AVCHD for consumer use is another hint of their strategy.
JVC does not belong to Panasonic anymore, is this correct? Anyway, JVC has been relying onto MPEG-2 for quite a long time, after all it invented HDV. JVC tried pushing MPEG-2 to consumers, but their TOD format was a mistake. Now JVC partnered with Sony and acquired a well-known XDCAM wrapper for MPEG-2 stream. So, JVC remains in MPEG-2 land, AND it does not mind using cheap SD cards. I would expect a successor to the HM100, with better ergonomics and lower price.
What about Canon? Unlike Panasonic and Sony, Canon does not have its own media format. SD or CF? AVCHD or MPEG-2? Anyone wants to venture a guess or share a rumor? The XH-A1 dates back to 2006, Canon must be readying something.
P.S. 24A from the V1U edits beautifully in Vegas, and renders very fast into AVC with Sony's AVC codec, about 2.5 times faster than into WMV with Microsoft's codec. After making 720p24 AVC output, I muxed it with AC3 soundrack in tsMuxer, then dropped into MultiAVCHD to create AVCHD file structure, then copied onto SDHC card, inserted into my Panasonic Blu-ray player, and voila! a 720p24 video on my HDTV. Nice.
My preferences are:
