I use an Odyssey 7Q+ for UHD 25p recording coming from an A7S or an A7SII.
Normally I appreciate it as monitor to find focus for both cameras one after the other, first A7SII, then the A7S. I then do record the UHD 25p A7S signal through HMDI with the Odyssey, and keep the A7SII disconnected but recording internally.
I really would like being able to switch the input-signal of the Odyssey from time to time. At the moment I do have to change the HDMI connection on camera side for every switch.
So:
Is there a robust and 100% reliable HDMI switch/splitter available, which could be used instead of changing the cable? I tried something like this but it simply does not work, broken signal for HDMI1, no valid signal for HDMI2:
https://www.amazon.com/Fosmon-HD8024-Bi-Directional-Switcher-Passthrough/dp/B00LFX1UDM/
(frankly, I used this one from German Amazon:
https://www.amazon.de/gp/product/B00EOVD30A/ )
Another solution could be to have a HDMI>SDI converter to use the SDI inputs of the Odyssey and switch the inputs in Odyssey between HDMI and SDI and keep both cameras connected.
Anything you would recommend as trustworthy?
A $1000 and heavy hardware won’t be possible, but maybe there’s something below.
Thanks in advance!
So:
Thanks in advance!
