FS7: HDMI and SDI output
RTRES
Hi, I´m shooting 4K with my FS7 but I need to go out to a Teradek cube HDMI and also to an SDI monitor at the same time, but I can't figure it out how to do it. The instructions on the owners manual does´t work. Thanks for your help.
Rafa
There's definitely a way to do it as I fumbled my way around and got 1) HDMI to Nyrius Aries Pro 2) SDI to 7Q, simultaneously.
I don't have the FS7 in front of me, but I seem to remember I had to change the output signal to 1080 i, as in "interlaced." After that, the signal was able to go to both Nyrius transmitter and 7Q.
I see. The only way to get both outputs working is to set the camera to 1080i 59.94fps, or 1080P 59.94fps, then both HDMI and SDI will have interlaced and progressive output, respectively, simultaneously.
