videoteque73
Hi,
I'm pretty new to this forums, I read them, in the hope to understand this "high definition for the rest of us" movement. Today I have been (nearly by chance) in a JVC presentation of the HD100. Forgive my bad english, I am a spanish living in Italy, I don't remeber half the spanish, still didn't learn italian...
The presentation was modest, the model we looked at was a working prototype and the JVC employee told us there are only five models like these in Europe. They hope to receive the production models in July.
The presentation lacked several things, unfortunately. There was a little set on a table with some toys and a "back-focus" checker printed in a sheet of paper. The camera was operated in 30p and we watched the results in an HD CRT JVC monitor... They justified 30p because there was also an LCD and they said it wouldn't take 25p (???). In PAL it can rec 24p, 25p, 30p. What it lacked is that nobody recorded the signal to tape and then watched, we watched the direct output. We hadn't the possibility to try in exterior either.
My conclusions are:
The camera seems to have been THOUGHT well. Not like those camcorder or digital cameras with a lot of gimmicks and no ergonomy. Buttons seem to be where they need to. The feeling is also good, no cheap plastic.
The progresive scanning is also a good pro. I have not tested many cameras lately, but the HD100 was near a 5100 (1/2" 3CCD camcorder interlaced). The "back focus" checker "tilted" in the 5100 monitor, but on the HD100 the image was 100% solid. No edges, lines or interlaced problems. Rock solid images.
The 30p didn't bothered me. I am used to my old AG-EZ1, which in frame mode, recs a sort of progressive, but not very fluid. The HD100 produced a much better motion. I hope in 25p it's more or less the same.
I had a fear and it is called low light. So much has been talked about Sony HDV's lossing sensitivity that I had serious doubts. Some of the people who were there had the same fear, so we tried the camera in dark zones. JVC rates it F8 at 2000lux. I suppose it all depends where do you come from, from my EZ1 the low light performance is good. There are two points to help. Gain is pretty invisible at 3dB and doesn't disturb even at 6dB (direct output, I don't know how the codec handles this noise). I don't remember maximum Gain, but is pretty unusable... The other good point is that there are 1/15 and 1/7.5 slow shutters.
So I survived the low light and progressive motion fears. Also I heard the tripod adapter costs nearly 1000€, but it's for the pro tripods. You can use a normal tripod with it.
They said that the little batteries should last one hour, and the big ones a couple of hours (zoom activity dependent).
A lot of things remain unresolved...
How does the HDV codec work with 720p signals?? Most owners of HDV equipement doesn't complain, so if HDV can take 1080i, 720p should compress much better...
How you can capture the firewire output?? They said most software is compatible but it wasn't very clear to me. If you use the Firestore, they said any editing software can access the files and edit right away(??). The "workflow" hasn't been clearly explained, in any case the JVC employee didn't seem to have actually used a camera or edited something. I may be wrong. So this point remains to be seen.
In any case the demo convinced me pretty much. The talk about Sony's HDV was a little in the funny side, saying that how can you call HD a camcorder with 960x540 pixels CCDs. Etc, etc. But from what I read most Z1 owners are happy. It remains to be seen what 1080p is better, 1080i from 960x540 pixels CCDs or 720p with native resolution CCDs enlarged. Who wants to the test???
This was all!!!
My conclusions are:
This was all!!!
