Larry Rutledge
Fest Master
Folks -
There seems to be a glitch in the authentication system for the festival. If you've never logged in to dvxfest before, or you have changed your user name since the last login, then it will not let you log in.
I have identified the issue, but it will be a day or so before I can resolve it. In the meantime I have a work around. Just PM me and I'll set you up so you can log in.
Sorry for the inconvenience.
When you PM me, I will try to get to it as quickly as possible. But if it takes me a little while to get back to you with the workaround, you can login with the following user:
User Name: test_user
Password: test_user
This will allow you to download films, and once I get your real login corrected then you will be able to login as your self and, if applicable, vote.
Thanks,
Larry
Password: test_user
Thanks,
Larry
