Has dvx separate rec/play heads?
terjes
planning to buy a cheap minidv camera to capture to my mac...in order not to wear the heads on my dvx 100...but does the dvx have separat play and record heads? ... if so, i dont need to buy a "capture camera".....
and do a "capture camera" deliver the same picturequality when i capture, as the dvx give?...(i take the tape from the dvx...put it in another camera to capture to mac)
sincerely terje
A cheap capture camera will give you the same results as capturing with the DVX, and it will save you wear and tear on your good camera.
