I just did a test shoot a few days ago with an HVX 200 in a green screen studio.
I have been running the results through some keying programs, and have been getting funny halo problems.
I'd like to figure out what the problem is so that I can correct it for the real shoot in a few weeks.
I shot to P2 cards. I then used Raylight Raymaker to convert the .mxf files to .avi files so that I could work with the footage in After Effects.
Finally, I used the Primatte Keyer to generate my matte. The results were really good, except I would get an outline around the foreground images.
I took a closer look at the original footage, and there is a bright outline around the edges of the foreground image.
If you take a look at the attached image, and blow it up to 200% or 400%, you'll see it.
So, rather than having an edge transition that goes from black (the color of the actors' clothing) to green, it goes from black to almost white-green, to green. So, the keyer gets rid of the green, but not the faint white line around it.
The result of all of this is that the composite looks very good against a light background, but terrible against a black / dark background.
I am wondering if this could be due to some camera setting like edge enhancement, or is this a typical lighting problem?
I have a frame grab PNG file at:
http://ewc.securesites.net/rawframe2.png
Thanks!
- Eugene
Thanks!
- Eugene
