Hacked error clips and DTV software
churasan
first, special thanks to Vitaliy and tester13's member for this incredible tool and useful setting infomations.
there's a 24p native patch's bug for now, shooting stopped suddenly.
but, I recognize that there are 2 types of errors,
1st: shooting stops but camera doesn't freeze, and clip survive though it has a data with some rogue frames.
2nd: shooting stops and camera freeze, and 0 bytes clip is made.
I have a question about 1st type clip.
Dear anyone who use Premiere pro CS5 or Vegas Pro or EDIUS,
can error clips play and be edit on those softwares?
on the other boards in Japan, I heard that CS5 with 64bit PC is OK and EDIS not.
best regards,
chrasan
#sorry for my bad English...
Reason of such freeze is some bugs inside encoder multipled to no error processing.
Most errors in encoder, muxer and other related parts result in freeze rather than normal processing and file closure. Hack just exposed all this dirty things. I think no unit testing where performed or test cases had been impropertly made.
As for damaged clips.
You can ask cbrandin to add fixing routines to his StreamAnaliser, may be he could do it.
Vitaliy, thanks for an immediate answer.
I'll do that.
again, thank you Vitaliy.
