im thinking about getting the tascam dr100 for $250Preamp or no, your signal is still going to go through the noisy Zoom preamps. The Juiced and the Riggy send mic level so that's no help. A preamp that sends line level might give a slight improvement but I would be surprised if it would be significant since AIR when presented with a line level input it just pads it down to mic level and sends it through the same preamps anyway.. The real solution is to buy a better recorder - not all digital products are created equal. By the time you added the cost of outboard devices to the base cost of the Zoom you will have spent enough to have bought higher quality to begin with anyway. In terms of total cash outlay it's always cheaper to get the right stuff right from the git-go.
The Zoom H4n is not a bad recorder if you can feed it a good MIC level signal. ( or padded down LINE level signal )
ZOOM H4n : RMS MIC NOISE FLOOR
MIC LEVEL 10 : -78 dB
MIC LEVEL 20 : -78 dB
MIC LEVEL 30 : -78 dB
MIC LEVEL 40 : -76 dB
MIC LEVEL 50 : -76 dB
MIC LEVEL 60 : -73 dB
MIC LEVEL 70 : -68 dB
MIC LEVEL 80 : -64 dB
MIC LEVEL 90 : -63 dB
MIC LEVEL 100 : -60 dB
...So if you can keep the amount of gain at level 60 or lower, the noise-floor is better than -73 dB, which can produce great results.
would you recommend getting something like the ntg2 and keep the h4n, and mic at 70 then using a preamp or buying a tascam?
ill take a lookThere's a Marantz PMD661 in the sale forum for relatively cheap. Not to be confused with the older and far noiser 660 which is also for sale in the forum. Pretty decent and standard in public radio circles. The Oade Brothers modded 661 is even better if you can afford it. I use a Roland R-26 and think it probably has the best pre's for the price. It's far better than the Tascam and any Zoom.
The Tascam buys you another 6-10 dB ( with a lower noise-floor ) depending on the setting, but it also falls apart when pushed to it's HIGH mic gain setting.
- What are you trying to record sound for?
- Indoors or outdoors?
- If indoors, what sort of space are you shooting in?
- How reflective are the floors and walls?
- How many people are your recording?
- Will you have a boom-operator?
Shotguns ( like the Rode NTG-2 ) are great mics outdoors, but don't work so well indoors.
I am focused on weddings currently. This is the sound that we received from the zoom h4n but im not liking how theirs noise in the background
Yes, the audio you are recording could be improved a fair bit.
Have you considered using small lav mics on both the bride and groom, and have them recording "wild" sound into a tiny recorder like the Olympus LS-7 ?
Countryman EMW Lav Mic (White)
Micro-Cat Lav Windscreen (White)
Countryman EMW Lav Mic (Black)
Micro-Cat Lav Windscreen (Black)
Olympus LS-7 Recorder
...The Olympus recorder weighs 3 ounces and runs for 30 hours on 2 AAA batteries. With a good lav mic it sounds quite good. ( I have used this when shooting interviews outdoors with a micro-cat to stop wind-noise )
I'm not a wedding shooter, so I can't tell you what the best lav mics are for weddings, but I have had good results with the Countryman EMW. ( my go to lav mic is the TRAM 50, which costs more )
...For narrative work, I would normally shoot with lav mics, and also have a boom-op running a shotgun outside / hyper-cardioid inside. Lav mics are great, but you have to practice to get to know how to place them properly.
but i do preferred wired
would you suggest using a lav and the zoom?
for $520 the marantaz 601 seems like a good choice it seems
what software are you using? Singulars doesn't always work well with my recordingsFor something like a wedding where you really can't fix a problem during the ceremony, I would also go with wired mics. This is why I like using wired lav mics into small digital recorders. Synch is easy to fix in post if you know what you are doing. ( I can synch hours of video and audio in a couple of minutes using a $20 Windows audio tool )
It would sound good, but where the heck are you going to stick a big clunky zoom H4n recorder.
The Zoom H1 recorder doesn't have a limiter circuit, isn't as well made as the Olympus LS-7, and has pretty poor interface controls. I bought a H1 for testing, but I've rarely used it.
I honestly don't think a better recorder is going to help you here.
I really think your problem is how you are micing things. Well placed lav mics are pretty much invisible and record great sound if set-up properly.
The other advantage to lav mics, is that you can have several going at the same time, so if something screws up with one lav, you will usually have other lavs to rely on.
thank you for those suggestionsBack to your audio problem...
Since you are already having the wedding couple hold a Sure SM58 mic during the ceremony, one other solution that might work for you is to use a Sennheiser UHF wireless hand-held microphone and feed the audio into your camera or into your Zoom H4n recorder.
Sennheiser EW135-p G3 SKM100 G3 Handheld Microphone
This is an absolutely great sounding handheld wireless mic, that has built-in internal suspension so there is virtually no handling noise at all from holding the mic, and the electronics have been tuned to bring out the best sound quality from the Sennheiser mic capsules. ( you can swap mic capsules that have different mic sensitivity patterns )
Here's a video I shot way back in January, that uses this mic, and is recorded directly into my Panasonic GH2 camera. ( no external recorder was used )
PositiveLite.Com interviews Ronnie Burkett
i found i can rent these for free
sony uwp-v1
one more thing would you recommend the ls 7 over the h2n if i could get them at the same price?
I'm thinking of using
the ls-7 or h2n + wireless lav
h4n for ambient sound
or marantz pmd 661 + wireless lav
Then you should test them and see how good the sound is. It should be good if the lav mic is placed properly.
These are quite different recorders.
The H2n recorder is great for ambient sound recording, as you can set it to record audio in a full 360 degrees spread. I use these when ever I have to shoot people around a boardroom table.
What I like about the Olympus LS-7 is mainly it's size, it's price ( $127 at B&H Photo ), and that it runs for 30 hours on one set of batteries.
The LS-7 is a very small recorder. You could fit four LS-7 recorders in the space of one Zoom H2n recorder. So being so small it's very easy to hide in a person's pocket, or clip it to their belt, or hide it in a woman's dress.
All of these combos would work well. My preference is for the LS-7 because it's low cost and it's very small ( so it's easy to hide ), and 30 hours on one set of batteries is amazing.
Also, Rick's suggestion of using a Sennheiser MD-42 or MD-46 mic is another route to consider. ( it's a better choice than the Sure SM58 mic you were using in the video you posted ) I like the EW135-p G3 SKM100 G3 Handheld Mic I used in the video because there is no mic cable with a wire-less mic, the electronics are tuned for the mic capsule, and the mic is self powered.
