siniarch
Ok. I'm about to put this on ebay, but I thought I'd check here first. I have a:
It has next to no use at all (Drum Head has 22hrs), so its MINT condition.
I bought it to do a film with my best friend when I moved to LA, but things didn't work out back then.
Now I bough the HVX and will not be using this one. But for 2k and all you get its a great deal.
The Century Optics wide angle lens was around $800.
The Anton Bauer Charger & batteries around $1400.
The camera was around $6000
The case was $150
Anyway, you get the idea. Its a Shoulder Mount camera that will make you look very professional at a lower price than the dvx100.
Please let me know if you want it ASAP
I also have the Varizoom Lens Control VZ Pro-F
http://www.varizoom.com/products/controls/vzprof.html that I was going to try to adapt to the HVX, but would also let it go for $150 if you wanted it.
- GY-DV500 camera with
- 2 Anton Bauer batteries (proforma 3) one might not hold charge
- and dual Charger
- Wide angle lense adapter from Century optics
- Fujinon S14x7.3B12U Lens
- 62mm circular polarizer
- 62mm circular UV
- 95mm Rubber Hood and 95mm to 4 1/2" filter adapter
- base plate
- Kalimar Case with Foam cutout
The case was $150
