Guidelines for basic adjustments
Mark-P
Can anyone recommend any guidelines for basic adjustments that should be made whenever calibrating the HVX prior to a shoot?
Example:
step one: focus,
step two: white balance,
step three: adjust iris,
step four: adjust shutter speed.
Is there anything else? Can anyone recommend a different order for these steps?
Thanks for any help.
white balance
adjust shutter
adjust iris
focus
kick the AC and tell him he's fired !
Add to that things like the recording format, scene file selection, and OIS mode selection.
And last but not least don't forget your audio -- checking the input selection (channels), XLR power, LINE vs. MIC level, audio output of the mikes if applicable, the level dials on the camera, and monitor using a good headset.
To obtain shallower d.o.f. (unless you have a 35mm adapter)
1) totally open the iris
2) set the lights/shutter/ND filter to obtain the right exposition
3) white balance (compare always the manual WB with the preset BW to have a reference
4) focus
5) shoot!
