JHouser
Zab said:Hi! I'm a bit confused. Could I use a lens kit I have (28mm, 50mm, and a zoom 70/210mm) used on a manual 35mm Pentax with the Guerrilla/Micro 35? And also a Zoom from a Canon EOS, which is automatic?
And finally, could I use the Guerilla/Micro 35 with my Chrosziel 4x4 mattebox with rods?
Thanks a lot for the info.
BTW I have seen footage absolutly amazing, AMAZING! Congratulations for your work on these adapters boys.
When you say Pentax do you mean Pentax screw (M42) or Pentax Bayonet. currently we do not support Pentax Bayonet. As long as your Chrosziel Mattebox is Arri Mini Spec you will be fine with the Guerilla35 rod setup. If not, You will need to supply your own rods. But yes, the Guerilla35 supports a MiniBridge plate in that case.
