downtownbrown
I have been reading every post I can find here about green screen settings and set up.
I've found that the sharpness is an issue so dialing the sharpness down helps.
I haven't particularly found any posting about where the camera should be physically set up from subject(I have talent standing on a green screen cyc approx. 10-12' from background). Should it be set up wide, tele and sweet spot of the lens(f-stop)...
Also any experience with shutter settings?
1080 vs. 720.
Are you guys doing a lot of work to remove halo(dark & white lines around subject foreground)...Is the issue lighting or sharpening or 4:2:2/combination...I've read several reasons but still not sure if I can get a good enough result shooting to p2 dvcpro or should consider capturing directly via bmd intensity via the component cables...
I'm sure you've all been down this road and this info is possibly already here but I am still unsure and was hoping some of you might have some answers to my ?'s...
Thanks in advance.
1080 vs. 720.
Thanks in advance.
